Ventilsteuerung 1.2 12V [English]
  • Hello , I haven't seen English Zone so I write here
    I bought Seat Ibiza 1.2 12v ( 159 000 km ) Do I need to change distribution( ventilsteuerungs ) ? , Thanks ! and Regards !
    Einmal editiert, zuletzt von Nviduum () aus folgendem Grund: Links entfernt
  • Hi Aki,
    welcome to the Forum.
    the 1.2 12V engine doesn't have a distributor, but 3 single ignitioncoil packs.
    If you encounter problems with the engine, please write down a short description, I'm shure we can help you!
    KR
    Bene
    PS: I just edited the Thread Title a bit :)
  • Hello,
    With ignition coil is everything fine , I've used a bad word , I mean timinig belt, Do I have to change after buying a car ?? Thnks for help.
    The 1.2 12V has a (terribly weak) timing chain. As these are a known weakpoint (slipping exhaust camshaft, broken chain tensioners), it is best to change it. There are several uprated parts for this, including modified guiding rails and tensioners.
